Emacs ElementaryX: Elementary Emacs configuration coupled with Guix
Fork of Emacs Bedrock: stepping stones to a better Emacs experience
Table of Contents
- 1. Why you should not use
emacselementaryx - 2. How to start
elementaryxwithguix(recommended)? - 3. How to start
elementaryxwithdocker(alternative if you don't haveguix)? - 4. First steps with
elementaryx
This page may be viewed online in html or pdf, while its sources are located on gitlab.inria.fr.
This project is a fork of the 1.2 version of the original emacs
bedrock by ashton314. As mentioned in its synopsis, the original
emacs bedrock was "intended to be copied once and then modified as
the user grows in knowledge and power." We believe that the original
version of bedrock is an excellent starting kit to learn about
modern emacs (emacs 29.1 or later) and we strongly encourage
emacs users to play with it.
1. Why you should not use emacs elementaryx
1.1. But use the original bedrock
elementaryx aims at achieving some specific workflows. In a way, it
may be viewed as an extension of the original emacs bedrock by
ashton314 to achieve them. On the other hand, it breaks some of the
very nice features of the original bedrock. For instance, the
original bedrock is delivered through a single git repository and
depends only on one external package by default, which makes it very
nice to play with. On the contrary, the present revisited version –
elementaryx – is split into multiple repositories and may have many
dependencies, which makes it hard to use. In addition, the focus on
the considered workflows of the present version is certainly useless
or suboptimum for many (most) emacs users.
1.2. But use other starter kits
While, according to its synopsis, the original bedrock is an
"extremely minimal emacs starter kit", there exist much more
fully-featured starter kits such as spacemacs or doomemacs. These
starter kits provide an excellent user-experience, are developed and
maintained by hundreds of contributors. The elementaryx suite does
not – and will not – achieve 1% of their capacity, nor ergonomics.
Though, as shown by asthon314 with the original bedrock, it is
possible to design a pleasant set up of emacs with a modern emacs
(version 29.1 or more), and we hope that this revisited version may
also be pleasant to use for performing a few selected workflows.
1.3. Because you are not on linux or you do not want to use the guix package manager
As discussed in Section 2, we rely on the guix package
manager to use this elementaryx. It can be installed on any linux
distribution (see below) but:
- you may not be on
linux; - or you may not want to install yet another package manager within
your
linuxdistribution.
In these cases, we do not recommend either to use elementaryx. Note
that it is nevertheless possible to use it with docker as explained
below.
2. How to start elementaryx with guix (recommended)?
2.1. In a nutshell (recommended)
In a nutshell, assuming we have guix available (see below in Section
2.2), we can launch elementaryx in an isolated shell with
guix time-machine using these guix-hpc fixed channels as follows:
mkdir -p "$HOME/org-roam" mkdir -p "$HOME/references" mkdir -p "/tmp/$(whoami)/elementaryx-test/.emacs.d" wget https://gitlab.inria.fr/elementaryx/elementaryx.gitlabpages.inria.fr/-/raw/main/dotfiles/bash-elementaryx/.bashrc.elementaryx -O "/tmp/$(whoami)/elementaryx-test/.bashrc.elementaryx" wget https://gitlab.inria.fr/elementaryx/elementaryx.gitlabpages.inria.fr/-/raw/main/channels-fixed.scm -O "/tmp/$(whoami)/elementaryx-test/channels-fixed.scm" cd "/tmp/$(whoami)/elementaryx-test/" SHELL="bash" guix time-machine --channels=/tmp/$(whoami)/elementaryx-test/channels-fixed.scm -- shell --share=/tmp/$(whoami)/elementaryx-test/ --share="$HOME/org-roam" --share="$HOME/references" --expose=/tmp/$(whoami)/elementaryx-test/.bashrc.elementaryx=$HOME/.bashrc --expose=$HOME/.config/guix/current=/guix --expose=/tmp/.X11-unix --expose=$XAUTHORITY --expose=/etc/ssl/certs --preserve="^SHELL|^DISPLAY$|^XAUTHORITY$|^TERM$" -CNW icecat emacs-elementaryx-as-default -- bash -c 'GUIX_PROFILE="/guix" ; . "$GUIX_PROFILE/etc/profile" ; emacs'
The rest of the section explains these latter instructions and propose
alternative execution modes. The above proposed execution mode
corresponds to the concatenation of the preliminary setup from Section
2.3 and the isolated execution from
2.4.1.1. If you are happy with this
execution mode you can skip the rest of the section and go to Section
4 to play with elementaryx.
We just mention before that, that, although we recommend it, it is not
necessary to create and share the $HOME/org-roam and
$HOME/references as suggested above. In case you do not want to
create and share them, we can create them in
"/tmp/$(whoami)/elementaryx-test/" instead. In this case, proceed as
follows:
mkdir -p "/tmp/$(whoami)/elementaryx-test" mkdir -p "/tmp/$(whoami)/elementaryx-test/org-roam" mkdir -p "/tmp/$(whoami)/elementaryx-test/references" mkdir -p "/tmp/$(whoami)/elementaryx-test/.emacs.d" wget https://gitlab.inria.fr/elementaryx/elementaryx.gitlabpages.inria.fr/-/raw/main/dotfiles/bash-elementaryx/.bashrc.elementaryx -O "/tmp/$(whoami)/elementaryx-test/.bashrc.elementaryx" wget https://gitlab.inria.fr/elementaryx/elementaryx.gitlabpages.inria.fr/-/raw/main/channels-fixed.scm -O "/tmp/$(whoami)/elementaryx-test/channels-fixed.scm" cd "/tmp/$(whoami)/elementaryx-test/" SHELL="bash" guix time-machine --channels=/tmp/$(whoami)/elementaryx-test/channels-fixed.scm -- shell --share=/tmp/$(whoami)/elementaryx-test/ --share="/tmp/$(whoami)/elementaryx-test/"="$HOME/org-roam" --share="/tmp/$(whoami)/elementaryx-test/"="$HOME/references" --expose=/tmp/$(whoami)/elementaryx-test/.bashrc.elementaryx=$HOME/.bashrc --expose=$HOME/.config/guix/current=/guix --expose=/tmp/.X11-unix --expose=$XAUTHORITY --expose=/etc/ssl/certs --preserve="^SHELL|^DISPLAY$|^XAUTHORITY$|^TERM$" -CNW icecat emacs-elementaryx-as-default -- bash -c 'GUIX_PROFILE="/guix" ; . "$GUIX_PROFILE/etc/profile" ; emacs'
2.2. Required dependency: guix
As mentioned in Section 1.1, elementaryx
is composed of multiple (tiny) git repositories and has
many dependencies (a few emacs dependencies, and many non emacs
dependencies). As a consequence, it is not straightforward (at all) to
use. Therefore we rely on a robust deployment tool – namely guix –
to set it up. Note that the guix package manager can be installed on
any linux distribution. We refer to guix manual for installing
guix and assume guix is available in the following.
Note that elementaryx is not packaged in the
main channel of guix but in the guix-hpc channel, which must
therefore be enabled (see guix-hpc). This is why the channels we use
include the guix-hpc channel.
The interested reader might read the guix definition of the present
elementaryx suite but this is not necessary at all for
proceeding.
2.2.1. Pre-built binaries
We refer to guix-hpc reference for setting up pre-built binaries.
2.2.2. Check up
In the following, we assume that guix and guix-hpc are set up.
2.3. Preliminary step: folder and file creations
We proceed with a few folder and file creations:
mkdir -p "$HOME/org-roam" mkdir -p "$HOME/references" mkdir -p "/tmp/$(whoami)/elementaryx-test" mkdir -p "/tmp/$(whoami)/elementaryx-test/.emacs.d" wget https://gitlab.inria.fr/elementaryx/elementaryx.gitlabpages.inria.fr/-/raw/main/dotfiles/bash-elementaryx/.bashrc.elementaryx -O "/tmp/$(whoami)/elementaryx-test/.bashrc.elementaryx" wget https://gitlab.inria.fr/elementaryx/elementaryx.gitlabpages.inria.fr/-/raw/main/channels-fixed.scm -O "/tmp/$(whoami)/elementaryx-test/channels-fixed.scm"
$HOME/org-roamwill be used for storing non-hierarchical org-roam notes and TODOs;$HOME/referenceswill be used for storing (bibtex) bibliography;/tmp/$(whoami)/elementaryx-test/will be used for testing purpose;/tmp/$(whoami)/elementaryx-test/.emacs.d/will be used as anemacsinit directory (not necessary in an isolated container);/tmp/$(whoami)/elementaryx-test/.bashrc.elementaryxwill be used as a minimalistbashrcset up (enable direnv, …);/tmp/$(whoami)/elementaryx-test/channels-fixed.scmwill be used as channels forguix time-machineorguix pull.
Note that an even more minimalistic /.bashrc setup can be used as
follows (rather than the wget above command):
echo "eval \"\$(direnv hook bash)\"" > "/tmp/$(whoami)/elementaryx-test/.bashrc.elementaryx"
Note also that in the long run, $HOME/org-roam and
$HOME/references might instead be symbolic links to git
repositories.
2.4. Start elementaryx
Assuming guix is available (see Section 2.2) and the
preliminary folder and file creations are done (Section
2.3), multiple options are then available to
start elementaryx and play with it.
The most simple way is to use the emacs-elementaryx-as-default guix
package. This package sets up a minimalist default.el emacs init
file (see emacs init file reference), basically consisting of
(use-package elementaryx-full) (see source) for requesting
the emacs elementaryx package. We also use the icecat package for
convenient check out of html exports (see below for the
corresponding workflow).
Here are multiple options for starting elementaryx, from the most
conservative to the most flexible.
2.4.1. Execution within an isolated container from both the home directory and the rest of the system
- With
guix shellandguix time-machine(recommended)
elementaryxmay be executed within an isolated container (guix shell -C, see guix shell reference) from both the home directory and the rest of the system with guix time-machine using these guix-hpc fixed channels as follows:cd "/tmp/$(whoami)/elementaryx-test/" SHELL="bash" guix time-machine --channels=/tmp/$(whoami)/elementaryx-test/channels-fixed.scm -- shell --share=/tmp/$(whoami)/elementaryx-test/ --share="$HOME/org-roam" --share="$HOME/references" --expose=/tmp/$(whoami)/elementaryx-test/.bashrc.elementaryx=$HOME/.bashrc --expose=$HOME/.config/guix/current=/guix --expose=/tmp/.X11-unix --expose=$XAUTHORITY --expose=/etc/ssl/certs --preserve="^SHELL|^DISPLAY$|^XAUTHORITY$|^TERM$" -CNW icecat emacs-elementaryx-as-default -- bash -c 'GUIX_PROFILE="/guix" ; . "$GUIX_PROFILE/etc/profile" ; emacs'
- With
guix shellbut notguix time-machine(not recommended for a tutorial / testing purpose)
cd "/tmp/$(whoami)/elementaryx-test/" SHELL="bash" guix shell --share=/tmp/$(whoami)/elementaryx-test/ --share="$HOME/org-roam" --share="$HOME/references" --expose=/tmp/$(whoami)/elementaryx-test/.bashrc.elementaryx=$HOME/.bashrc --expose=$HOME/.config/guix/current=/guix --expose=/tmp/.X11-unix --expose=$XAUTHORITY --expose=/etc/ssl/certs --preserve="^SHELL|^DISPLAY$|^XAUTHORITY$|^TERM$" -CNW icecat emacs-elementaryx-as-default -- bash -c 'GUIX_PROFILE="/guix" ; . "$GUIX_PROFILE/etc/profile" ; emacs'
- Explanations
This execution mode ensures that the execution of
elementaryxdoes not interfere with the rest of the system, nor with the home directory of the user.We allow only the
$HOME/org-roam,$HOME/referencesand/tmp/elementaryx-testrepositories created in Section 2.3 to be writable.In addition, we allow nested usage of
guix(-Woption) and we make sure that all the channels from the main profile are made available (--expose=$HOME/.config/guix/currentandGUIX_PROFILE=$HOME/.config/guix/current ; . $GUIX_PROFILE/etc/profile). We also allow for network usage (-Noption).We define
bashas the defaultshell(SHELL="bash"and--expose=/tmp/$(whoami)/elementaryx-test/.bashrc.elementaryx=$HOME/.bashrcand--preserve=^SHELL$).We furthermore allow for graphical (
--expose=/tmp/.X11-unix --expose=$XAUTHORITY --preserve="^DISPLAY$|^XAUTHORITY$") and terminal (--preserve=^TERM$) execution ofemacs. Hereemacs(emacs) is started in graphical mode; but it could also be started in terminal mode (withemacs -nw).The
--expose=/etc/ssl/certsallows for exposing system X.509 certificates (see guix manual), required for instance to authenticate web servers overhttps.We refer to guix shell reference for an exhaustive presentation on how to use
guix shell.
2.4.2. Execution in an isolated container from the rest of the system but writable in the home directory
This alternative execution mode allows for interacting in a writable
mode with the home directory (--share="$HOME") and the /tmp
directory (--share=/tmp/) but still ensures not to interfere with
the rest of the system.
- With
SHELL="bash" guix time-machine --channels=/tmp/$(whoami)/elementaryx-test/channels-fixed.scm -- shell --share="$HOME" --share=/tmp/ --expose=$HOME/.config/guix/current=/guix --expose=$XAUTHORITY --expose=/etc/ssl/certs --preserve="^SHELL|^DISPLAY$|^XAUTHORITY$|^TERM$" -CNW icecat emacs-elementaryx-as-default -- bash -c 'GUIX_PROFILE="/guix" ; . "$GUIX_PROFILE/etc/profile" ; emacs --init-dir=/tmp/$(whoami)/elementaryx-test/.emacs.d/'
- With
SHELL="bash" guix shell --share="$HOME" --share=/tmp/ --expose=$HOME/.config/guix/current=/guix --expose=$XAUTHORITY --expose=/etc/ssl/certs --preserve="^SHELL|^DISPLAY$|^XAUTHORITY$|^TERM$" -CNW icecat emacs-elementaryx-as-default -- bash -c 'GUIX_PROFILE="/guix" ; . "$GUIX_PROFILE/etc/profile" ; emacs --init-dir=/tmp/$(whoami)/elementaryx-test/.emacs.d/'
2.4.3. Non isolated execution in a pure environment
The --container guix shell option requires kernel support. If this
support is not available, an alternative is to use the --pure guix
shell option. It does not ensure isolation but clears environment
variable definitions to reduce (but not guarantee) unattended
interaction with the rest of the system.
- With
SHELL="bash" guix time-machine --channels=/tmp/$(whoami)/elementaryx-test/channels-fixed.scm -- shell --pure --preserve="^SHELL|^TERM$" icecat emacs-elementaryx-as-default -- bash -c 'GUIX_PROFILE="$HOME/.config/guix/current" ; . "$GUIX_PROFILE/etc/profile" ; emacs --init-dir=/tmp/$(whoami)/elementaryx-test/.emacs.d/'
- With
SHELL="bash" guix shell --pure --preserve="^SHELL|^TERM$" icecat emacs-elementaryx-as-default -- bash -c 'GUIX_PROFILE="$HOME/.config/guix/current" ; . "$GUIX_PROFILE/etc/profile" ; emacs --init-dir=/tmp/$(whoami)/elementaryx-test/.emacs.d/'
2.5. Starting elementaryx with non standard keybindings or on a remote machine
The philosophy is to follow as much as possible the reference emacs
29.1. When additional packages are used, we follow as much as possible
the proposed default suggestions both in terms of enabled
configuration and key bindings.
2.5.1. vim users
There is no advanced support for vim but vim users might want to
start emacs with the -f evil-mode option to enable basic vim key
binding support:
emacs -f evil-mode
For instance, the suggested execution in Section 2.1 may be appended as follows:
SHELL="bash" guix time-machine --channels=/tmp/$(whoami)/elementaryx-test/channels-fixed.scm -- shell --share=/tmp/$(whoami)/elementaryx-test/ --share="$HOME/org-roam" --share="$HOME/references" --expose=$HOME/.config/guix/current=guix --expose=/tmp/.X11-unix --expose=$XAUTHORITY --preserve="^SHELL|^DISPLAY$|^XAUTHORITY$|^TERM$" -CNW icecat emacs-elementaryx-as-default -- bash -c 'GUIX_PROFILE="/guix" ; . "$GUIX_PROFILE/etc/profile" ; emacs -f evil-mode'
2.5.2. windows-like copy-paste users (C-c C-v)
Users used to copy-paste with C-c C-v may want to start start emacs
with -f cua-mode:
emacs -f cua-mode
SHELL="bash" guix time-machine --channels=/tmp/$(whoami)/elementaryx-test/channels-fixed.scm -- shell --share=/tmp/$(whoami)/elementaryx-test/ --share="$HOME/org-roam" --share="$HOME/references" --expose=$HOME/.config/guix/current=/guix --expose=/tmp/.X11-unix --expose=$XAUTHORITY --preserve="^SHELL|^DISPLAY$|^XAUTHORITY$|^TERM$" -CNW icecat emacs-elementaryx-as-default -- bash -c 'GUIX_PROFILE="/guix" ; . "$GUIX_PROFILE/etc/profile" ; emacs -f cua-mode'
2.5.3. elementaryx on a remote machine with mouse-tracking support
You may want to start emacs elementaryx on a remote machine through
ssh. In this case, assuming ssh was performed with X11 forwarding
(typically via ssh -X or ssh -Y), emacs may be started with no X
(-nw) for performance reason, while still enabling
mouse-tracking
support (-f xterm-mouse-mode):
emacs -nw -f xterm-mouse-mode
For instance, assuming a remote machine with no the suggested execution in Section
2.4.3.1 (with --pure option) may be appended as
follows:
SHELL="bash" guix time-machine --channels=/tmp/$(whoami)/elementaryx-test/channels-fixed.scm -- shell --pure --preserve="^SHELL|^TERM$" icecat emacs-elementaryx-as-default -- bash -c 'GUIX_PROFILE="$HOME/.config/guix/current" ; . "$GUIX_PROFILE/etc/profile" ; emacs --init-dir=/tmp/$(whoami)/elementaryx-test/.emacs.d/ -nw -f xterm-mouse-mode'
This execution mode may be a typical usage on a remote computer where container support would not be available.
3. How to start elementaryx with docker (alternative if you don't have guix)?
3.1. Retrieve or generate the docker image
3.1.1. Option 1: Retrieve it from docker hub (recommended)
docker pull emmanuelagullo/guix-hpc-elementaryx:latest
3.1.2. Option 2: Generate it with guix (for information, and reproducibility)
guix_hpc_elementaryx_docker_tarball=$(guix time-machine --channels=/tmp/$(whoami)/elementaryx-test/channels-fixed.scm -- system image --image-type=docker elementaryx-docker-image.scm) docker load < ${guix_hpc_elementaryx_docker_tarball} docker tag guix:latest emmanuelagullo/guix-hpc-elementaryx:latest
Note that this is how the image was generated before being pushed to docker hub with:
# We assume: `docker login` has been performed to pursue docker push emmanuelagullo/guix-hpc-elementaryx:latest # image pushed online: https://hub.docker.com/r/emmanuelagullo/guix-hpc-elementaryx
3.2. Create, start and execute the container
guix_hpc_elementaryx_docker_container=$(docker create -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -e XAUTHORITY=$XAUTHORITY -e TERM=$TERM --platform linux/amd64 emmanuelagullo/guix-hpc-elementaryx:latest) docker start $guix_hpc_elementaryx_docker_container # As root: # docker exec -ti $guix_hpc_elementaryx_docker_container /run/current-system/profile/bin/bash --login # As user "panoramix": docker exec -u panoramix -ti $guix_hpc_elementaryx_docker_container /run/current-system/profile/bin/bash --login
3.3. Start emacs elementaryx
We are now logged onto the image and can start emacs elementaryx from there:
emacs
3.4. Support of X11 and tty modes
3.4.1. X11 mode
The X11 support may require some additional set up, such as xhost
+local:docker (with guix: guix shell xhost -- xhost
+local:docker). We warn the reader about potential security issues
and refer to docker reference for further information on that topic.
3.4.2. tty mode
It is also possible to run in terminal mode with mouse support. We
refer the reader to docker reference for possible additional
docker setup. Regarding emacs, it can be started with:
4. First steps with elementaryx
We assume to be all set up to play with elementaryx, may the user
has started it with guix or docker, as discussed above.
The elementaryx software suite aims TO BE CONTINUED.
4.1. Graphical user interface (GUI)
As with most editors, most common operations can be performed using the graphical user interface (GUI), an important feature for discoverability.
In particular, the menu-bar allows one to
